Was making my first clock face ever using https://dev.fitbit.com/getting-started/ as a guide since I have never done any coding before. I was pleased with my result - getting the picture I wanted, the placement of the time exactly where I wanted it and format (12h/24h). So, not so complicated I guess, but proud of myself 😛
Then I was thinking that I would like to add day and date in the bottom left corner, BPM in the bottom right corner and a battery indicator in the top left corner. The battery indicator is not that important, but would like to get the others in place. Or maybe the day/date in the bottom and BPM in the top left corner...
I've been trying for hours looking at the forums here and looked at ozibyte.com to see if I can get it the way I want it but just can't get it to work. It just stays as I had originally made it....I can feel some techrage coming on...
Please help....
Sorry, I think I totally misread your post, or combined it with another.
Firstly you need to add <text> labels for each bit of information you want to display:
https://dev.fitbit.com/build/guides/user-interface/svg/#text
Then you can put an ID on each <text> element, and use CSS to position and style those <text> elements:
https://dev.fitbit.com/build/guides/user-interface/css/
Then in your code, you can get a handle on each <text> element by using document.getElementById()
https://dev.fitbit.com/build/guides/user-interface/javascript/#getelementbyid-
Now you just need to work out where to get the values you need, and put the values into each <text> element by doing: myThing.text = somevalue;
For example, the step count comes from here:
https://dev.fitbit.com/build/reference/device-api/user-activity/#variable-today-
There's an example of heart rate here:
https://dev.fitbit.com/build/guides/sensors/heart-rate/
