11-01-2017 04:40
11-01-2017 04:40
Hi,
Has anyone tried using the Orientation Sensor?
I haven't been able to get the sensor to work.
Would love some sample code if possible.
Thanks heaps in advance,
Echo
11-01-2017 07:15
11-01-2017 07:15
11-01-2017 15:52
11-01-2017 15:52
Thanks Allan for your reply.
I've got the Accelerometer working. I'm talking about the OrientationSensor API.
I'm trying this as there also seem to be problems with the Gyroscope as well.
11-02-2017 02:33
11-02-2017 02:33
03-03-2018 13:07
03-03-2018 13:07
Same happens to me:
const orientationSensor = new OrientationSensor(); setInterval(() => { console.log(orientationSensor.readings); if (orientationSensor.readings) { const { quaternion } = orientationSensor.readings; console.log(quaternion); if (quaternion) { console.log(quaternion.join()); } } }, 1000);
Prints forever:
[22:06:21]undefined app/index.js:28,1 [22:06:22]undefined app/index.js:28,1 [22:06:23]undefined app/index.js:28,1 [22:06:24]undefined app/index.js:28,1 [22:06:25]undefined app/index.js:28,1 [22:06:26]undefined app/index.js:28,1 [22:06:27]undefined app/index.js:28,1 [22:06:28]undefined app/index.js:28,1 [22:06:29]undefined app/index.js:28,1 [22:06:31]undefined app/index.js:28,1 [22:06:32]undefined app/index.js:28,1 [22:06:33]undefined app/index.js:28,1 [22:06:34]undefined app/index.js:28,1 [22:06:35]undefined app/index.js:28,1 [22:06:36]undefined app/index.js:28,1 [22:06:37]undefined app/index.js:28,1 [22:06:38]undefined app/index.js:28,1 [22:06:39]undefined app/index.js:28,1 [22:06:40]undefined app/index.js:28,1 [22:06:41]undefined app/index.js:28,1 [22:06:43]undefined
03-06-2018 16:49
03-06-2018 16:49
Hi Sergius,
Sorry for taking so long to respond, busy days.
I'm working on the orientation sensor these days. Once I have more information I'll share here.
Eddie
05-11-2018 05:44
05-11-2018 05:44
Hi,
any news?
Thank you.
Regards,
Mark
05-11-2018 12:57 - edited 05-11-2018 12:58
Have you tried the example in the sensor guide?
It uses onreading plus it starts the sensor orientation.start() which it needs for operation otherwise you are just reading an empty record. Also it sets the interval so you should not need to use setInterval().
import { OrientationSensor } from "orientation"; let orientation = new OrientationSensor({ frequency: 60 }); orientation.onreading = function() { console.log("Orientation Sensor Reading: " + "timestamp: " + orientation.timestamp, "quaternion[0]: " + orientation.quaternion[0], "quaternion[1]: " + orientation.quaternion[1], "quaternion[2]: " + orientation.quaternion[2], "quaternion[3]: " + orientation.quaternion[3]); } orientation.start();
