03-13-2019 05:36 - edited 03-13-2019 06:09
I'm trying to get the angle between the normal of the display and the ground.
Can someone show me how?
Here my test app:
/app/index.js
import document from "document";
import { OrientationSensor } from "orientation";
import { display } from "display";
display.autoOff = false;
let orientation = new OrientationSensor({ frequency: 5 });
let inputs=[
document.getElementById("q0"),
document.getElementById("q1"),
document.getElementById("q2"),
document.getElementById("q3")
let outputs=[
document.getElementById("a0"),
document.getElementById("a1"),
document.getElementById("a2"),
document.getElementById("a3")
function normalize(value){
if (value>1) return 1;
if (value<-1) return -1;
return value;
function toDegrees(value){
let res=value*180/Math.PI;
return res.toFixed(0);
function onOrientationChanged(q){
let qw=normalize(q[0]);
var angle = 2 * Math.acos(qw);
outputs[0].text=toDegrees(angle);
let s=Math.sqrt(1-qw*qw);
var angles=[0,0,0];
for (var i=0;i<4;i++){
inputs[i].text=q[i].toFixed(2);
if (i>0){
angles[i-1]=q[i]*angle;
if (qw>=0.000001) angles[i-1]=angles[i-1]/s;
outputs[i].text=toDegrees(angles[i-1]);
return angles;
onOrientationChanged([ 0.2088969, 0.5646126, 0.5646126, 0.5646126]); //expected x=90 y=90 z=90
orientation.onreading = function() {
onOrientationChanged(orientation.quaternion);
setTimeout(function(){
orientation.start();
},2500);
/resources/index.gui
<svg> <text x="5%" y="20%" text-length="6">w</text> <text x="5%" y="40%" text-length="6">x</text> <text x="5%" y="60%" text-length="6">y</text> <text x="5%" y="80%" text-length="6">z</text> <text id="q0" x="20%" y="20%" text-length="6">q0</text> <text id="q1" x="20%" y="40%" text-length="6">q1</text> <text id="q2" x="20%" y="60%" text-length="6">q2</text> <text id="q3" x="20%" y="80%" text-length="6">q3</text> <text id="a0" x="60%" y="20%" text-length="6">angle</text> <text id="a1" x="60%" y="40%" text-length="6">x angle</text> <text id="a2" x="60%" y="60%" text-length="6">y angle</text> <text id="a3" x="60%" y="80%" text-length="6">z angle</text> </svg>
Best Answer03-13-2019 12:43
03-13-2019 12:43
Here's a messy extract from a test of mine:
let orientation = new OrientationSensor({ frequency: 1 });
let qr = orientation.quaternion[0];
let qi = orientation.quaternion[1];
let qj = orientation.quaternion[2];
let qk = orientation.quaternion[3];
// Roll:
let t0 = 2 * (qr*qi + qj*qk);
let t1 = 1 - 2*(qi*qi + qj*qj);
let thetaX = Math.atan2(t0, t1)*180/3.14159;
// Pitch:
let t2 = 2 * (qr*qj - qk*qi);
t2 = t2 > 1 ? 1 : t2;
t2 = t2 < -1 ? -1 : t2;
let thetaY = Math.asin(t2)*180/3.14159;
// Yaw:
let t3 = 2*(qr*qk + qi*qj);
let t4 = 1 - 2*(qj*qj + qk*qk);
let thetaZ = Math.atan2(t3, t4)*180/3.14159;
orientAXEl.text = Math.round(thetaX);
orientAYEl.text = Math.round(thetaY);
orientAZEl.text = Math.round(thetaZ);
rollEl.groupTransform.rotate.angle = thetaX; // +x is pitch up
pitchEl.groupTransform.rotate.angle = thetaY; // +y is roll right-wing-down
yawEl.groupTransform.rotate.angle = thetaZ; // +z is yaw left
orientation.start();It doesn't do quite what you want, but perhaps the roll, yaw and pitch angles will be more comprehensible and useful to you.
03-13-2019 12:43
03-13-2019 12:43
// Roll:
// Pitch:
// Yaw:
03-14-2019 02:52
03-14-2019 02:52
Perfect thank's
