04-25-2018 06:41
04-25-2018 06:41
I have not experienced this before but i have an issue where the PNG's dispensary and reappear (they all have load"sync". The annoying thing is when I get notifications on the watch they disappear and then the watch face goes blank. This seems to be mainly effected by notifications. It does not happen on my other watch faces.
Anybody experienced this before or have any ideas why it might be happening?
Best Answer04-25-2018 14:37
04-25-2018 14:37
Can you tell us more about your clock?
Does it use a lot of images?
Are you doing any animations, or transforms?
Are you manipulating the images in javascript?
Is it in the GAM already?
Best Answer12-20-2018 08:34
12-20-2018 08:34
Its been a while you posted, but have you been able to find solution for this? Same things happens for me as well
Best Answer12-23-2018 18:49 - edited 12-23-2018 18:50
I'm experiencing the same thing too. It appears the watch app is force unloading and then immediately loaded again, which causes the flickering. My watch is on the latest firmware.
Best Answer12-27-2018 02:08
12-27-2018 02:08
Does your watch face use the heart rate monitor? I find the heart rate monitor crashes the watch if
hrm.stop()
is called more than once on firmware 3.0.
