03-14-2021 23:19
03-14-2021 23:19
Hi everyone.
I'm beginner for Fitbit studio, Javascript, and PHP, so I can't find where the problem is.
I made device application in which the array of HeartRate in 20 seconds and the timestamp were sent to companion smartphone when I tapped the button, using messaging API.
This worked well.
The sent data was like this (when JSON.stringfied).↓
data={"heartRateArray:[84,84,84,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null],
"nowdate":"Mon Mar 15 2021 14:19:12 GMT+09:00"}
To save the data in the companion device, I built a local server running in Android, installing KSWeb.
I posted the data using fetch() to getJSON.php.
It seemed to work well ,because I could get "Success"
import * as messaging from "messaging";
messaging.peerSocket.addEventListener("message", (evt) => {
console.error(JSON.stringify(evt.data));
sendServer(evt.data);
//Send to server
async function sendServer(sentdata){
await fetch('http://127.0.0.1:8080/getJSON.php', {
method: 'POST',
headers:{'Content-Type': 'application/json'},
body: JSON.stringify(sentdata)
.then(response => {console.log("Success");})
.catch(error => {console.log("Failed!!You'll fail to get PhD.!!!!!");})
Since I want to confirm that the local server could get the data sent from companion app, I made getJSON.php file below.
The localhost page showed "Get JSON!", NULL.
<html>
<head>
<title>Test</title>
<meta http-equiv = "Content-Type" content = "text/html; charset=utf-8">
</head>
<body>
<h2>Get JSON!</h2>
<?php
// get POST data
$json = file_get_contents("php://input");
// JSONstring to array
$contents = json_decode($json,true);
// Debug
var_dump($contents);
</body>
</html>
I have no idea why the localhost page displays NULL.
The code in the getJSON.php is wrong?
Or the data have not been posted to localserver?
Please help.
03-24-2021 07:12 - edited 03-24-2021 07:16
body:data in my case data is a JSON string. This code 100% works. This api call is used for more than 100 times a day. my url is an https, but that is only necessary for remote servers.
Then it might be your local server not responding well. This is my php code
header("Access-Control-Allow-Origin: *");
header("Content-Type: application/json; charset=UTF-8");
$round = json_decode(file_get_contents('php://input'), true);
03-23-2021 07:58
03-23-2021 07:58
fetch(url,{method: "POST", body: data}).then(res => res.json()).then(response => {
console.log("response "+JSON.stringify(response));
}).catch(e => {
console.log("Upload failed"+JSON.stringify(e)+" "+url);
Hope my code snipped from below helps. I think you have to parse your data to json instead of setting the header Content-Type to Json
03-24-2021 07:04
03-24-2021 07:04
Thank you for your advice.
I tried your code, but I got 'Upload failed'.....😭
03-25-2021 21:08
03-25-2021 21:08
Thank you for the further information.
I understood the problem was in my php code.
It will takes a time to solve the problem in my php code ,because I have little knowledge about php.
(This is my first experience to write php code.)
I'll start to learn the basics of php code.
