Yes, but how you do it depends on which type of setting you are setting:
For Selects do a settingsStorage.setItem to the settingsKey of the Select, setting it to one of the values in the options.
So to set 24 hour mode as the default selected value in this Select example...
<Select
label={`Clock mode`}
settingsKey="hourmode"
options={[
{name:"24 hour mode", value:"24h"},
{name:"12 hour mode", value:"12h"}
/>... you would need to do:
settingsStorage.setItem("hourmode", JSON.stringify({"selected":[0],"values":[{"name":"24 hour mode","value":"24"}]})) ;
For toggles you just set it to true or false:
settingsStorage.setItem("useweather", JSON.stringify({"value":"true"})) ;
For TextInput and Sliders you just set it like this:
settingsStorage.setItem("theKey", "any text");or
settingsStorage.setItem("sliderKey", 42;
<Select
options={[
Liljeberg's answer is wonderful - but one detail could be simplified:
a select just needs something like this:
settingsStorage.setItem("hourmode", '{"selected":[0]}') ;
