01-15-2022 09:00
01-15-2022 09:00
Hello!
Looking at https://dev.fitbit.com/build/guides/user-interface/svg-components/buttons/
to make an icon-button, following the instructions step by step does not allow me to make a icon button.
In particular (using Digital Time clock example):
index.js:
import clock from "clock";
import * as document from "document";
import { preferences } from "user-settings";
import * as util from "../common/utils";
const myButton = document.getElementById("button-1");
// Update the clock every minute
clock.granularity = "seconds";
// Get a handle on the <text> element
const myLabel = document.getElementById("myLabel");
// Update the <text> element every tick with the current time
clock.ontick = (evt) => {
let today = evt.date;
let hours = today.getHours();
if (preferences.clockDisplay === "12h") {
// 12h format
hours = hours % 12 || 12;
} else {
// 24h format
hours = util.zeroPad(hours);
let mins = util.zeroPad(today.getMinutes());
myLabel.text = `${hours}:${mins}`;
index.view:
<svg class="background">
<text id="myLabel" />
<use id="button-1" href="#icon-text-button" class="icon-text-button bottom application-fill" />
</svg>
style.css
.application-fill { fill: fb-blue; }
.foreground-fill { fill: fb-white; }
.background-fill { fill: fb-black; }
#button-1 #text {
text-buffer: "ICON BUTTON";
#button-1 #image {
href: "filename.png";
#myLabel {
font-size: 80;
font-family: System-Bold;
text-length: 32;
text-anchor: middle;
x: 50%;
y: 50%+40;
fill: white;
widget.defs
<svg>
<defs>
<link rel="stylesheet" href="styles.css" />
<link rel="import" href="/mnt/sysassets/widgets/text_button.defs" />
</defs>
</svg>
Where is the problem? I am not very expert of JS, I searched some answers but no solution. I think this might help lots of people looking to make an icon button with a personalized image.
Thank you,
Naz
Best Answer01-22-2022 11:06
01-22-2022 11:06
Following same tutorial, can make the example on buttons works, I get this one error from console log (running in emulator):
[8:00:43 PM]Error 2 Invalid path '/mnt/sysassets/text_button.defs'
and then (obvious at this point):
[8:00:43 PM]Error 22 Could not find symbol '#text-button' in button1
any help apreciated 🙂
Roberto
Best Answer01-22-2022 11:13
01-22-2022 11:13
oups, issue solved in my case, the right path is, I was missing "widgets/"
As per your problem Nazago, may be you need to keep the below line in widget.defs, I see it is missing:
<link rel="import" href="/mnt/sysassets/system_widget.defs" />
