12-21-2018 02:12
12-21-2018 02:12
Hi, I have designed a Versa Watch face but due to Copyright laws I can not share this watch face with others, I can however upload it to my own device and use it there. I can use the studio.fitbit.com site and build it so it goes to the watch, but it seems to crash after a few days. I can also publish the watch face except I do not know how to put the published watch face onto my watch, any help would be great
Best Answer01-08-2019 12:42
01-08-2019 12:42
You can add your clock into the gam privately, but you can't publish it publicly. When it's privately added, you can use the gam link to install it without using Studio
01-08-2019 12:42
Best Answer01-10-2019 13:14
01-10-2019 13:14
So question here, how I can publish a clockface pulicly?
Best Answer01-10-2019 18:34
01-10-2019 18:34
@sspyli You need to upload your app/clockface to GAM https://gam.fitbit.com/ and follow the easy procedure.
Best Answer01-10-2019 20:57
01-10-2019 20:57
I have already published my clockface , but the status shows private.
Best Answer01-10-2019 21:11
01-10-2019 21:11
Did you submit it for review?
01-10-2019 21:12
01-10-2019 21:12
I see! Thank you:)
04-04-2019 20:06
04-04-2019 20:06
How long does it take to get approval from the Fitbit once I submit my application for review(publish it publicly)?
Best Answer04-05-2019 01:07
04-05-2019 01:07
Usually it takes few days but if you are waiting for long maybe @JonFitbit could expedite it.
