05-30-2020 16:33 - edited 05-30-2020 16:34
Dear community,
I have the following issue. I am using the "use" keyword to create my text,
Now I want when the user click on a text something to happen.
My code is:
<defs>
<symbol id="my-tile-item" href="#tile-list-item" focusable="false"
pointer-events="none" system-events="all">
<text id="text" />
<rect id="tile-divider-bottom" class="tile-divider-bottom" />
<rect id="touch-me" pointer-events="all" x="0" y="0" width="100%"
height="100%-2" opacity="0" />
</symbol>
</defs>
<use id="my-list" href="#tile-list">
<var id="separator-height-bottom" value="2" />
<use href="#my-tile-item" class="tile-list-item">
<set href="text" attributeName="text-buffer" to="Job" />
</use>
and the JS is:
Do you have idea why the JS couldn't create the click hook and show the information on the console?
Kind Regards,
Aleks
05-30-2020 16:38
05-30-2020 16:38
tried pointer-events="visible"?
