01-08-2021 12:05
01-08-2021 12:05
Recently I had several of my clock faces rejected with steps value was not correct. One of the rejections also stated that the value was 0. I've tested the clock faces with the simulator for ionic, versa, versa lite, and versa 2. I've also tested using my physical ionic device. The steps are always correct.
So I'm at a loss for why I'm seeing different results than the testers approving clock faces.
Anyone seeing similar results?
Best Answer01-08-2021 12:58
01-08-2021 12:58
Could it be that you're using today.local.steps when you should be using today.adjusted.steps?
01-08-2021 12:58
Best Answer01-08-2021 13:37
01-08-2021 13:37
I was reading about using adjusted and will most likely try that.
Best Answer01-27-2021 05:13
01-27-2021 05:13
Confirming that since changing today.local.steps to today.adjusted.steps I have not had any more clock faces rejected.
