02-10-2018 01:02
02-10-2018 01:02
I wanted to ask how I am able to replace values in JSON files, without overriding the whole file and losing the rest of the property values. Because if I do it in the following way:
json_color.hours = element.data.value;
fs.writeFileSync("colors.txt", json_color, "json");I am always replacing the previous file and I only want to change one property value and keep the other remaining property values.
02-10-2018 02:26
02-10-2018 02:26
I would write the file only on app unload, and also use CBOR format for speed purposes.
import { me } from "appbit";
me.onunload = () => {
fs.writeFileSync("colors.txt", json_color, "cbor");
02-10-2018 02:26
02-10-2018 02:26
02-10-2018 06:07
02-10-2018 06:07
For settings, which your example appears to be, then @JonFitbit response is certainly the best solution.
If you were collecting data, for example sensor data for later use, then take a look at writeSync, which is for binary file use. It does add a level of complexity, but also opens up reading or updating particular 'records' at will. Each record will be a fixed byte length. I was 'playing about' with writeSync yesterday and have working code if this route is of interest/use (read/write/update) @Senorts.
02-10-2018 06:54
02-10-2018 06:54
Thank's very much for the help.
Best Answer02-10-2018 08:00 - edited 02-10-2018 08:03
As per your message @Senorts, here you are. Please remember this is test code to confirm functionality and usage of writeSync.
import * as fs from "fs";
let fh = 0;
let fileName="filename.bin";
// setup variables for updating the record
var sentBuffer = new ArrayBuffer(1);
var sentFlag = new Uint8Array ( sentBuffer, 0, 1 ); // 1 x 1 bytes
sentFlag[0] = 1;
//setup variables for the record format
let recSize = 58;
var buffer = new ArrayBuffer(recSize);
var dtMillies = new Uint32Array ( buffer, 0, 2 ); // 2 x 4 bytes
var gpsLat = new Float64Array( buffer, 8, 1 ); // 1 x 8 bytes
var gpsLon = new Float64Array( buffer, 16, 1 ); // 1 x 8 bytes
var gpsSpeed = new Float64Array( buffer, 24, 1 ); // 1 x 8 bytes
var gpsAccuracy = new Float64Array( buffer, 32, 1 ); // 1 x 8 bytes
var gpsHeading = new Uint16Array ( buffer, 40, 1 ); // 1 x 2 bytes
var heartRate = new Uint16Array ( buffer, 42, 1 ); // 1 x 2 bytes
var steps = new Uint16Array ( buffer, 44, 1 ); // 1 x 2 bytes
var altitude = new Uint16Array ( buffer, 46, 1 ); // 1 x 2 bytes
var ascent = new Uint16Array ( buffer, 48, 1 ); // 1 x 2 bytes
var descent = new Uint16Array ( buffer, 50, 1 ); // 1 x 2 bytes
var reading = new Uint32Array ( buffer, 52, 1 ); // 1 x 4 bytes
var battery = new Uint8Array ( buffer, 56, 1 ); // 1 x 1 bytes
var sent = new Uint8Array ( buffer, 57, 1 ); // 1 x 1 bytes
let myDate=Date.now()
let recCount=0;
let firstUnsent = 0;
writeRecord();
writeRecord();
showFileDetails();
firstUnsent = findFirstUnsent();
if (firstUnsent>0) {
updateRecordAsSent(firstUnsent);
showRecordsToConsole();
function writeRecord() {
fh = fs.openSync(fileName, 'a+');
dtMillies[0] = parseInt(myDate/100000000);
dtMillies[1] = myDate%100000000;
gpsLat[0] = 179.987654321
gpsLon[0] = -179.123456789
gpsHeading[0] = Math.floor(Math.random() * 360);
gpsSpeed[0] = 2.123456791
heartRate[0] = 120 + Math.floor(Math.random() * 80);
gpsAccuracy[0] = 21.2134254723
steps[0] = Math.floor(Math.random() * 3);
altitude[0] = 10 + Math.floor(Math.random() * 1991);
ascent[0] = 4
descent[0] = 0
battery[0] = 78
reading[0] = 1
sent[0] = 0
fs.writeSync(fh, buffer); // write the record
fs.closeSync(fh); // and commit changes -- important if you are about to read from the file
function showFileDetails() {
let stats = fs.statSync(fileName);
if (stats) {
recCount=stats.size/recSize;
console.log("File size: " + stats.size + " bytes");
console.log("Number of Records: " + recCount);
console.log("Last modified: " + stats.mtime);
function getNumberOfRecords() {
recCount=0;
if (stats) {
return recCount;
function findFirstUnsent() {
let retVal=0;
for (let i = 0; i < recCount; i++) {
fs.readSync(fh, buffer, 0, recSize, i*recSize );
if ((sent[0]==0) && (retVal===0)) {
retVal=i+1;
i=recCount;
fs.closeSync(fh);
return retVal;
function updateRecordAsSent(recordID) {
fs.writeSync(fh,sentBuffer,0,1,(recSize*recordID)-1);
fs.closeSync(fh);
function showRecordsToConsole() {
recCount=getNumberOfRecords();
fh = fs.openSync(fileName, 'r+');
console.log("Record: "+(i+1)+" Millies:"+(dtMillies[0]*100000000+dtMillies[1])+" Lat:"+gpsLat[0]+" Lon:"+gpsLon[0]+" Heading:"+gpsHeading[0]+" Speed:"+gpsSpeed[0]+" HR:"+heartRate[0]+" Accuracy:"+gpsAccuracy[0]+" Steps:"+steps[0]+" Alt:"+altitude[0]+" Asc:"+ascent[0]+" Des:"+descent[0]+" Bat:"+battery[0]+" Reading:"+reading[0]+" Sent:"+sent[0]);
fs.closeSync(fh);
function packString(mystring) {
let i=0;
while (mystring.length<16) { mystring+=' '; }
for (i = 0; i < mystring.length; i++) {
usernameView[i]=mystring.charCodeAt(i);
function unPackString(usernameView) {
let retVal='';
let i=0;
for (i = 0; i < usernameView.length; i++) {
retVal+=String.fromCharCode(usernameView[i]);
return retVal
05-15-2020 22:28
05-15-2020 22:28
one really interesting thing i found in using @SunsetRunner's code it looks like the Uint*Arrays need to be in a certain order to pack them into the ArrayBuffer as tightly as possible. for example, i have two Uint*Arrays i'm passing to the buffer. if i put the Uint32Array first, i can get the record size down to 9 bytes. but if the Uint8Array is first, the record size has to be 16 bytes (almost twice as large). otherwise, i get an error. anyone know the logic behind this in the Fitbit SDK? does this have something to do with Endianness? Here's my code sample:
allows for a record size of 9 bytes:
var attention = new Uint8Array(buffer, 8, 1);
var dtMillies = new Uint32Array(buffer, 0, 2);
var attention = new Uint8Array(buffer, 0, 1);
var dtMillies = new Uint32Array(buffer, 8, 2);
