07-05-2019 10:07
07-05-2019 10:07
I am attempting to rotate a rect element 45 degrees. When I do it, it looks great on the simulator but on my actual device the rect get cut off.
<g transform="rotate(45)">
<rect id="blue" fill="dodgerblue" x="0" y="25%" width="130%" height="100%" />
</g>The results:
Result on Simulator
Result on Versa watch
How do I get the 2 to match?
07-05-2019 12:45
07-05-2019 12:45
I worked it out but not really what I would prefer. If I am wrapping the rect element in the g-container, the g-container will move with the rect element's x and y cords. When I rotate the element inside the g-container it will get cut off.
Starting point
rotated
So if I want to make sure it doesn't cut off I have to reduce the size of the blue box.
70% width
To get the look I was going for, I ended having to do 2 containers.
<rect fill="dodgerblue" x="0" y="25%" width="70%" height="70%" />
</g>
<rect fill="dodgerblue" x="25%" y="25%" width="70%" height="70%" />
</g>I would prefer to be able to add multiple transforms so I could do something like:
<g transform="rotate(45) translate(0, 25%)">
<rect fill="dodgerblue" width="100%" height="100%" />
</g>
07-05-2019 12:45
07-05-2019 12:45
Starting point
rotated
70% width
</g>
</g>
07-05-2019 13:47
07-05-2019 13:47
This is a known bug.
