02-18-2023 12:36
02-18-2023 12:36
How is this not working?
Using code from
https://dev.fitbit.com/build/guides/user-interface/svg-components/buttons/
widget.defs
<link rel="import" href="/mnt/sysassets/system_widget.defs" />
index.view
<svg class="background">
<use href="#text-button">
<set href="#text" attributeName="text-buffer" to="BUTTON" />
</use>
</svg>
result is:
[21:26:03]Error 22 Could not find symbol '#text-button' resources/index.view:2,1
[21:26:03]Error 22 Undefined attribute 'href' resources/index.view:2,1
[21:26:03]Error 22 Could not find element '#text' resources/index.view:3,1
[21:26:03]App Started
02-18-2023 23:02
02-18-2023 23:02
Thanks @kozm0naut @Gondwana - in the end was simpler to create a toggle button manually in SDK 6
<svg >
<rect x="10%" y="30%" height="20%" width="80%"fill="fb-yellow"/>
<rect x="11%" y="31%" height="18%" width="78%" fill="fb-black"/>
<text x="40%" y="42%" fill="white" font-size="35" font-family="System-Bold" > Push</text>
<rect id="btn1" pointer-events="visible" x="10%" y="30%" height="20%" width="80%" fill="fb-yellow" opacity="0"/>
</svg>
<svg >
<rect x="10%" y="60%" height="20%" width="80%" fill="fb-yellow"/>
<rect x="11%" y="61%" height="18%" width="78%" fill="fb-black"/>
<text x="40%" y="72%" fill="white" font-size="35" font-family="System-Bold" > Pull</text>
<rect id="btn2" pointer-events="visible" x="10%" y="60%" height="20%" width="80%" fill="fb-yellow" opacity="0"/>
</svg>
Toggle opacity = 0.5 on mousedown and opacity = 0 on mouseup - works identical to SDK 4.
Sometimes the simple things work best!
02-18-2023 12:41
02-18-2023 12:41
<link rel="import" href="/mnt/sysassets/widgets/text_button.defs" />
02-18-2023 13:07
02-18-2023 13:07
Thanks Peter - works
How about for #square-button-toggle or equivalent for SDK 6?
02-18-2023 13:14
02-18-2023 13:14
I think square button is deprecated. Its doco is here.
02-18-2023 13:18
02-18-2023 13:18
Thanks, I'm looking for toggle primarily.
02-18-2023 13:29 - edited 02-18-2023 13:32
The other problem is the text doesn't show
<use id="btn" href="#text-button" x="10%" y="$+7%" width="80%" fill="fb-green">
<set href="#text" attributeName="text-buffer" to="Push" />
</use>
All works fine with SDK 4.3, text shows and button toggles with mouse down/up
02-18-2023 20:59
02-18-2023 20:59
Try dropping the "#" on the set href... I don't know why the usage is inconsistent between use and set.
02-18-2023 22:22
02-18-2023 22:22
Thanks @kozm0naut - that also seems to be accepted.
However there doesn't seem to be an equivalent TOGGLE button in SDK 6, whereas in SDK 4 pressing the button can highlight it and removing your finger removes the highlight.
As @Gondwana says, "#square-button-toggle" appears to be deprecated.
In other words "removed", often referred to as "progress".
But if it is not replaced by something better, seems more like forced obsolescence or lack of backward compatibility, often occurs from reinventing the wheel, only to find the original round one was better!.
02-18-2023 23:02
02-18-2023 23:02
<svg >
</svg>
<svg >
</svg>
