SVG - Arc
ANSWERED
How can i change sweep-angle on runtime?
GUI:
<arc id="steps" x="30" y="20" width="100" height="100" fill="fb-lime"
arc-width="10" start-angle="0" sweep-angle="90" />
JS:
var arcSteps = document.getElementById("steps");
arcSteps.sweep-angle = "120"; <--- it doesnt work, build failed
arcSteps.sweepAngle = "120"; <--- it has no impact
1 BEST ANSWER
Accepted Solutions
Some of our SVG are lacking in this release. sweepAngle should be in the next update though!
11 REPLIES 11
Will start-angle be in it as well? I am going through the same issue.
Ps how do you guys do the circles in the watch faces without this function? Do you have an alternative idea/coding you are using?
Sorry for the bump, but this is something Im working on as well. Wondering how this is currently implemented in the gauges clock face.
when is the next release that would have start-angle & sweep-angle that can be changed during run-time?
xxxxx.sweepAngle started working for me.
I am not sure if there have been changes, but it does work now.
What function did you call to change the start angle and or sweep angle?
Also, when setting SVG style values from within JavaScript, how do I tell it 100% (or any percent actually)?
Thx!
Chuck
My code for sweepAngle is basically:
import document from "document";
let tideArc = document.getElementById("tideArc");
function processTideData(data) {
  var time = data[1].date;
  var epoch = data[1].dt;
  var orario = new Date(epoch * 1000);
  let now = Date.now();
  var timeDiff = Math.round((orario-now)/120000);
  tideArc.sweepAngle = Math.abs(180-timeDiff)
I can confirm this is also working for me. Quite exciting.
Did you every figure out how to set a start angle?
Hi,
Did you ever get this solved? I am experiencing the same issue.
Thanks.
NVM. I had a conflicting script in my code! thanks.
