Hello guys, I'm currently trying to make a fit bit app that will serve as an extra feature in my web application.
I need to authenticate my users and their private watch before they can post to my data base.
I try to find the best solution for making them register and get a secret token saved in their local storage, then using it when posting data to my server.
The process of going throw the mobile app => account => Versa 3 => Gallery => my app => settings => login is very user exhausting
Is there someone doing it differently?
Many thanks, David.
23:20
08:35
02-28-2023
23:20
08:35
Hi @DavidBer again, I gave up on the idea as it isn't really very practical from a user's point of view.
However, if your website does not require authorisation there is no need for the token at all.
Was able to get it working fine without but as mentioned previously it does require an internet access but you can register anything you want that way.
