05-08-2021 05:30
05-08-2021 05:30
Hi guys,
I am trying to make an analog clock where the second hand continuously moves and does not tick.
Do I need to create an animation for a full 360 degrees and repeat it indefinitely, or is there another way?
Thanks.
Best Answer05-08-2021 21:41 - edited 05-08-2021 22:18
Below is a solution that is working in index.view.
How do I start the rotation angle in Javascript from a different starting point depending on the seconds? For instance, if it is 15 seconds after the hour, I would like the animation to start from 90 degrees and not 0 degrees.
The expected 'secondsRotation.groupTransform.rotate.angle = 90' does not seem to work.
<g id="secondsRotation" pointer-events="visible" transform="translate(50%,50%)">
<animateTransform attributeType="rotate" from="0" to="360" begin="enable" dur="60" repeatCount="indefinite" />
<image x="-50%" y="-50%" href="images/seconds_hand.png"></image>
</g>
