Hello, a year ago I transferred data from companion to a server with this code:
// Listen for the onmessage event
messaging.peerSocket.onmessage = function(evt) {
// Output the message to the console
console.log(JSON.stringify(evt.data));
// Send information to the server
fetch('https://XXXX.es:3000/heartRate', {
method:'post',
headers: {
'Content-Type': 'application/json'
body:JSON.stringify(evt.data)
}).then(function(result) {
if (!result.ok) {
console.log(result.status + ': ' + result.statusText);
return;
console.log('Enviado paquete');
}).catch(function (err){
console.log(err)
}Now i can't use that server anymore and i would like to fetch to localhost:3000. It's where my nodeJS server can listen
//nodeJS server.js code
https.createServer(options, app).listen(port, (err) => {
if (err) {
return console.log('something bad happened', err)
console.log(`server is listening on ${port}`) });
[...]Is there a possibility to send data to my localhost through the companion? Later I need to insert that data in a mongo database with that server.js
