I've seen some things about sending info from the companion app to a server, which could be used to communicate data TO (not FROM) a PC if the server is running on a PC.
However, if I want to send data from a PC to Fitbit using this approach, it seems that I would have to implement a busy-wait where the companion app would have to periodically check for new data on the PC. That is really not ok.
Is there a way to do it using some feature of the SDK?
Because the other approach would also be quite cumbersome: Use the push notifications to send data to an app on the phone that would then issue a notification that should be displayed by Fitbit the same way Email and Calendar notifications are shown (which I would also have to figure out how to do).
Ideally, there would be a simple way in the SDK to allow sending data from the Fitbit to a PC and from the PC to Fitbit, even if that means going through the companion app.
I couldn't find anything that would cover this scenario on the SDK. Did I miss something? This would open the door for a whole new world in terms of Fitbit development.
Best AnswerI think you might be able to avoid polling by using WebSockets to send data to the companion. The companion may need to establish the connection first, but after that I think it's bidirectional.
You may still need to go via a server somewhere to get around SSL restrictions.
