07-17-2019 23:19
07-17-2019 23:19
Hi guys,
In Settings, is there a way to create a select list where each item contains a text image along side the name? Below is what I am trying to achieve but, I cannot get the image to come up.
<Select
label="Select with TextImageRow"
options={[
{ name: 'Label1', value: {location: 'Sub-Label', icon: 'https://xyz'} },
{ name: 'Label2', value: {location: 'Sub-Label', icon: 'https://xyz'} },
{ name: 'Label3',value: {location: 'Sub-Label', icon: 'https://xyz'} },
{ name: 'Label4', value: {location: 'Sub-Label', icon: 'https://xyz'} },
{ name: 'Label5', value: {location: 'Sub-Label', icon: 'https://xyz'} }
Best Answer07-17-2019 23:30
07-17-2019 23:30
I used this:
renderItem={
(option) =>
<TextImageRow
label={option.name}
icon={colIcons[option.value]}
07-17-2019 23:30
I used this:
renderItem={
(option) =>
<TextImageRow
label={option.name}
Best Answer07-18-2019 00:08
07-18-2019 00:08
Awesome! Thanks Catplace. That worked well.
For anyone else, below is the code I used in settings/index.jsx
const colIcons=['https://tinyurl.com/ybbmpxxq','https://tinyurl.com/ybbmpxxq','https://tinyurl.com/ybbmpxxq'];
function mySettings(props) {
return (
<Page>
<Select
label="Selection with icons"
settingsKey="listKey"
options={[
{ name: 'Label1', value: 0 },
{ name: 'Label2', value: 1},
{ name: 'Label3', value: 2}
renderItem={
(options) =>
<TextImageRow
label={options.name}
icon={colIcons[options.value]}
</Page>
07-29-2019 21:28
07-29-2019 21:28
How did you retrieve those keys in the index.js?
Best Answer07-29-2019 21:42
07-29-2019 21:42
Hi Dcable,
That is correct. There is a good example of this in the part ‘settings in action’:
https://dev.fitbit.com/build/guides/settings/
