03-14-2018 12:04
03-14-2018 12:04
I have a Mac running High Sierra.
I've been using Fitbit Studio and would like to test the new simulator, however, it's giving me a hard time.
Whenever I try to open the simulator app it automatically closes. I've tried uninstalling and reinstalling to no avail.
Any ideas?
03-15-2018 08:57 - edited 03-15-2018 09:07
Can you see if this log file contains any interesting information?
~/Library/Logs/Fitbit\ OS\ Simulator/log.log
Please don't paste the log here, it may contain authorisation tokens.
03-15-2018 09:07 - edited 03-15-2018 09:12
Hey Jon,
Thanks for responding. I'm not sure what qualifies as interesting haha.
Just sent logs via PM.
Cheers,
03-15-2018 09:08
03-15-2018 09:08
Can you send me the log via private message? Thanks
05-10-2018 14:20
05-10-2018 14:20
I'm also trying to run the simulator (v0.5.6, as downloaded through Fitbit Studio) on Mac High Sierra (v10.13.4), and am getting the following dialog:
Simulator failed to start: getaddrinfo ENOTFOUND localhost
localhost:63981, getaddrinfo ENOTFOUND localhost
localhost:63982
The following is showing up in the log file:
[2018-05-10 17:15:51.886] [error] appsim stderr: 2018-05-10 17:15:51.738 app[47281:20185698] ASSERT_Log: Type: 26 func_addr: 0x000bf6f0 lr: 0x00000000, file: ../../fb_private/fb_system/fbsys_notification.c, line: 211, func: _removeNotification, expr: false
[2018-05-10 17:15:51.985] [info] appsim stdout: [D][17:15:51.738][] Scheduler starting dispatch time: 1525986951738
Fb_AlarmMgr_Clean is running[A][17:15:51.970][] [I][17:15:51.970][] Houston, this is Ionic!!Simulator control server starting on 127.0.0.1:63981
[A][17:15:51.970][] Press ? anytime for help
[A][17:15:51.970][] Version: 32.4.19 (Apr 18 2018 15:44:42): Fake for tests
[A][17:15:51.970][] GNU_BUILD_ID:
mfgtst $
[2018-05-10 17:15:51.986] [error] appsim stderr: [2018/05/10 17:15:51:9708] NOTICE: libuv support not compiled in
[2018/05/10 17:15:51:9743] NOTICE: Creating Vhost 'default' port -1, 1 protocols, IPv6 off
[2018/05/10 17:15:51:9758] NOTICE: created client ssl context for default
[2018/05/10 17:15:51:9758] NOTICE: Creating Vhost 'default' port 63981, 1 protocols, IPv6 off
[2018-05-10 17:15:52.001] [error] appsim stderr: 2018-05-10 17:15 app[47281] (FSEvents.framework) FSEventStreamCreate: _FSEventStreamCreate: ERROR: could not allocate 0 bytes for array of path strings
[2018-05-10 17:15:52.002] [error] appsim stderr: 2018-05-10 17:15 app[47281] (FSEvents.framework) FSEventStreamScheduleWithRunLoop(): failed assertion 'streamRef != NULL'
2018-05-10 17:15 app[47281] (FSEvents.framework) FSEventStreamStart(): failed assertion 'streamRef != NULL'
[2018-05-10 17:15:52.609] [warn] 10 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63981
[2018-05-10 17:15:52.609] [warn] 10 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63982
[2018-05-10 17:15:53.614] [warn] 9 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63981
[2018-05-10 17:15:53.614] [warn] 9 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63982
[2018-05-10 17:15:55.620] [warn] 8 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63981
[2018-05-10 17:15:55.621] [warn] 8 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63982
[2018-05-10 17:15:58.625] [warn] 7 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63981
[2018-05-10 17:15:58.625] [warn] 7 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63982
[2018-05-10 17:16:02.630] [warn] 6 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63981
[2018-05-10 17:16:02.631] [warn] 6 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63982
[2018-05-10 17:16:07.641] [warn] 5 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63981
[2018-05-10 17:16:07.642] [warn] 5 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63982
[2018-05-10 17:16:13.649] [warn] 4 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63981
[2018-05-10 17:16:13.650] [warn] 4 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63982
[2018-05-10 17:16:20.661] [warn] 3 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63981
[2018-05-10 17:16:20.661] [warn] 3 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63982
[2018-05-10 17:16:28.673] [warn] 2 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63981
[2018-05-10 17:16:28.674] [warn] 2 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63982
[2018-05-10 17:16:37.681] [warn] 1 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63981
[2018-05-10 17:16:37.682] [warn] 1 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63982
Any thoughts or suggestions? (Initially, it was also complaining about a non-existent "root/Library/Application Support/Fitbit OS Simulator/user-settings" directory - I created "root/Library/Application Support/Fitbit OS Simulator/", and then it seemed to manage to create "user-settings" on the next invocation - but I'm still getting the above error(s).
05-10-2018 14:23
05-10-2018 14:23
BTW, if I try to execute the app via sudo at the command line, I get the following in response (ie, in the terminal shell):
[2018-05-10 17:21:31.845] [error] appsim stderr: 2018-05-10 17:21:31.679 app[47416:20203958] Calling FB_Assert_Fatal:
2018-05-10 17:21:31.680 app[47416:20203958] file: ../../fb_private/fb_system/fbsys_pkg_mgr.c
2018-05-10 17:21:31.680 app[47416:20203958] line: 289
2018-05-10 17:21:31.680 app[47416:20203958] func: (null)
2018-05-10 17:21:31.680 app[47416:20203958] msg : (null)
2018-05-10 17:21:31.680 app[47416:20203958] LR : 0x00000000
[2018-05-10 17:21:31.884] [info] appsim exit code: null (signal SIGABRT)
[2018-05-10 17:21:32.543] [warn] 10 retries left: Error: getaddrinfo ENOTFOUND localhost localhost:63981
... (ie, a bunch more retries before it finally quits retrying)
07-03-2019 05:30
07-03-2019 05:30
thread bump
