Simulator unable to uninstall clockface
Hi,
I am developing on Windows 10, targeting Fitbit Ionic.
I installed a test clockface from github. It is a simple
clockface displaying time, date, and HR.
The clockface runs fine, but when I try to uninstall
from the Simulator, the following occurs:
The Ionic face goes blank.
The clockface name is not removed from the cue.
Then the Simulator gives it's restart message.
When the Simulator restarts, the clockface is still
installed.
Thank you in advance for your assistance.
6 REPLIES 6
I think the simulator is a brilliant piece of work. However, it does get confused sometimes.
You can always delete the watchfaces by deleting the appdata (for the Fitbit simulator)
Details may be found in the following post by @JonFitbit
https://community.fitbit.com/t5/SDK-Development/Simulator-will-not-load/m-p/3887867?search-action-id...
Hmmm... I can't seem to find that path.
Inside my Local Disk(C:) -> Users -> [User account] -> I do not see an AppData folder.
Mayhaps this has something to do with a recently installed new fangled solid state partitioned drive where my OS resides?
Or is it just a simple security setting I am not familiar with on Windows 10?
Found it. Show Hidden Files.
You can also start typing the address and it will show up in the auto fill in selector. This works even if it's hidden.
Typing location in Windows Explorer search field?
File explorer, address bar:
