Is there a way to create animations to scroll smoothly?
It just does not look aesthetically pleasing on the eye and feels quite jarring when I focus on the screen of the watch, like I can see the pixel density and it's not ticking as it should, but dragging along continuously
There's the scrollview component for long pages of content.
https://dev.fitbit.com/build/guides/user-interface/svg-components/views/#scroll-view
If that doesn't suit, can you provide an example of what you're trying to achieve.
