Unfortunately we don't expose HRV. Accelerometer data is available (x,z,y) - https://dev.fitbit.com/build/reference/device-api/accelerometer/
with minhr and maxhr declared globally and reset after each variability calculation :
var hrm = new HeartRateSensor({ frequency: 1, batch: 1 });
// Declare an event handler that will be called every time a new HR value is received.
hrm.addEventListener("reading", () => {
// Peek the current sensor values - first of batch, ignore the others
//console.log("Current heart rate: " + hrm.heartRate);
hrLabel.text = hrm.heartRate;
lastValueTimestamp = Date.now();
if (maxhr < hrm.heartRate) {
maxhr = hrm.heartRate;
if (minhr > hrm.heartRate) {
minhr = hrm.heartRate;
Thank you YannisParis. Can I access data every minute? How can I know If current heart rate in rest situation or not ?what do frequency and batch parameters meaning? Thank you so much 🙂
Best Answerhttps://dev.fitbit.com/build/guides/sensors/heart-rate/
https://dev.fitbit.com/build/reference/device-api/heart-rate/
