I developed an App with SDK4.2 for Versa, Ionic...
Now I updated this app to SDK 5 for Versa3 and Sense.
Is it possible to publish this app by uploading the fba file in the app gallery manager with a different Version number or do I have to create a new entry with a new Title.
SDK 5 is only for Sense and Versa 3, and they use different files internally.
You can have the same title but it must be 2 different FBA files, one made with SDK 5 and the other with SDK 4.2.
Example:
Go to https://gallery.fitbit.com/ and search clocks for "MMXX"
You will see 7 SimpleClock... clocks, some are for Versas and Ionic, and some for Sense and Versa 3.
You can distinguish them visually by the different clock face, even though they have the same name.
When searching clocks within the Fitbit phone app, it will only return you the ones pertinent to your watch model, so it does the filtering for you.
Works fine.
Best AnswerCan I put two different FBA files to the same release/submission or should I do it sequentially? I didn't find a way to submit two FBA files in a single submission, so what I currently do is:
That's awkward. Is there a way to submit two files simultaneously?
