11-22-2019 12:44
11-22-2019 12:44
Hi All,
I am developing a watchface that has to reliability and regularly connect to our servers to pull data to be shown on the watchface.
As others have noted the messaging appears flaky. So I check the socket is open with the code below, and often disappears and nevers comes back.
messaging.peerSocket.readyState === messaging.peerSocket.OPEN
I do communicate with the companion every couple of minutes to maintain a connection, does not seem to work.
I made sure the Fitbit app is in the front, and has the background app refresh enabled and that bluetooth is working; in fact the Fitbit app showed the watch had just synched moments earlier , but still the connection was closed.
Is there anything people have found to resurrect the connection?
I had to go as far as removing the app from the watch to re-enable the connection.
Has anyone tries the suggestion on using file transfers instead of peer messages?
Does anyone have any suggestions? There needs to be no documentation on this.
Stumped
Geoff
11-27-2019 21:41
11-27-2019 21:41
Hello,
I am also experiencing difficulties regarding the reliability of the messaging API... I would really appreciate some feedback from the devs at Fitbit.
Thanks,
David
Best Answer11-28-2019 05:23
11-28-2019 05:23
Also have problems with all clockfaces after updating on Fitbit OS v.4 and SDK 4.0.
The problem is in Companion - it just unloading and doesn't wake up anymore.
