06-26-2020 21:04
06-26-2020 21:04
I decided to try and learn how to make my own clock face. I have no previous experience with JavaScript or SVG.
To get started I am trying to modify the clock tutorial to look light the stock Sundial clock face and was wonder how you would recommend going about creating the tick marks around the face. I was able to get a rectangle to rotate around the center but I am having trouble setting the color.
<defs>
<symbol id="ticks">
<g id="ticksGroup" transform="translate(50%,50%) rotate(0)">
<rect id="rect1" x="$-1" y="-50%+1" width="2" height="5%" fill="red"/>
</g>
</symbol>
<symbol id="numbers">
<text font-family="System-Regular" fill="red"/>
</symbol>
</defs>
<use href="#ticks">
<set href="#ticksGroup" attributeName="transform" to="translate(50%,50%) rotate(6)"/>
</use>
<use href="#ticks">
<set href="#ticksGroup" attributeName="transform" to="translate(50%,50%) rotate(12)"/>
<set href="#rect1" attributeName="fill" to="white"/>
</use>
Also, Is there an easier way to generate all the tick marks other then copying and pasting 60 times?
06-27-2020 21:43
06-27-2020 21:43
@mdb17 wrote:I decided to try and learn how to make my own clock face. I have no previous experience with JavaScript or SVG.
<defs>
<symbol id="ticks">
</g>
</symbol>
</symbol>
</defs>
<use href="#ticks">
</use>
<use href="#ticks">
</use>
Well,... if you want an element on the watch face, it seems you really do need to have a bunch of copies.
You can leverage the process using your css file.
I have less tick marks, and the code is like this:
index.gui:
<svg id="cFace">
<g transform="rotate(30)"><line/></g>
<g transform="rotate(60)"><line/></g>
<g transform="rotate(120)"><line/></g>
<g transform="rotate(150)"><line/></g>
<g transform="rotate(210)"><line/></g>
<g transform="rotate(240)"><line/></g>
<g transform="rotate(300)"><line/></g>
<g transform="rotate(330)"><line/></g>
</svg>
styles.css:
#cFace g line {
y1:-98;
y2:-117;
fill:white;
stroke-width:2;
Use the gui to place your element, and your css to define your repeated values
There may be another way to do this (perhaps through javaScript), but all javaScript is limited by memory.
Regards,
Reign
07-01-2020 12:32
07-01-2020 12:32
I used the javascript to produce the tick marks where I wanted them, then did a screenshot to capture the image, finally pulled it into a graphics editing program to save it ultimately as a .png file. Then I could simply include it in the background instead of having the watch code produce the clockface every time.
