Depending on which device you're using, if it has a gyroscope, that's the preferred way.
https://dev.fitbit.com/build/guides/sensors/gyroscope/
Note: Only the Fitbit Ionic, Fitbit Versa, and Fitbit Sense contain a gyroscope sensor.
Best AnswerThanks Jon!
For the Versa 3 and Versa 2, how would you approach detecting a lap (change in direction) without the gyroscope?
I think you'll need to do some research into the algorithms required when using an accelerometer to simulate a gyroscope.
https://electronics.stackexchange.com/questions/205644/simulate-gyroscope-through-mems-accelerometer
Another approach would be to record some data and plot it on a graph so you can see how the sensor is behaving during a swim.
https://dev.fitbit.com/build/guides/sensors/accelerometer/
Best Answer@JonFitbit any update on the introduction of lap counting while swimming on Charge 4? As I understood this feature is also missing on the Versa 4 and Sense.
@JonFitbit I am asking for all three devices since I got informatiin from the FitBit support that it is in the making.
I'd recommend asking in the product forums, this is the developer forum.
