03-17-2018 20:09
03-17-2018 20:09
I’d love to have the ability for my 1by one smart scale to Sync to my fit bit. Is this currently being worked on or can someone create a way for these to connect.
05-27-2020 08:58
05-27-2020 08:58
Yes, you can connect the two. I just did it and now get my 1byOne scale sending my Fitbit my weight!
03-19-2018 23:36
03-19-2018 23:36
I think you'd need to contact the manufacturer and ask them to do this.
05-04-2018 17:59
05-04-2018 17:59
I have the same scale and would like the same thing!
06-22-2018 06:08
06-22-2018 06:08
You can add me to that request also!
07-16-2018 22:40
07-16-2018 22:40
Did you ever get it to work?
@Jas_mine wrote:I’d love to have the ability for my 1by one smart scale to Sync to my fit bit. Is this currently being worked on or can someone create a way for these to connect.
08-31-2018 09:53
08-31-2018 09:53
The solution that the question responded to was not a solution; it was a comment.
05-27-2020 08:58
05-27-2020 08:58
