I’d love to have the ability for my 1by one smart scale to Sync to my fit bit. Is this currently being worked on or can someone create a way for these to connect.
Yes, you can connect the two. I just did it and now get my 1byOne scale sending my Fitbit my weight!
You can add me to that request also!
The solution that the question responded to was not a solution; it was a comment.
