12-10-2017 06:38 - edited 12-10-2017 06:38
I'm developing a clock face for the Ionic. I've been testing it out on my own device for the last few days and noticed that when the battery level was low, the "low battery" warning indicator appeared in the top left corner of the display behind some text on my clock face. Questions:
1. Can I override the behaviour or suppress the low battery indicator?
2. If I use the Power API to get battery level information, can I replace the built-in battery level indicator with my own?
3. Is it possible to find out the co-ordinates and dimensions of the built-in battery indicator so I can make sure the text of my clock face does not appear over the top of it?
Best Answer01-09-2018 13:08
01-09-2018 13:08
This is a system overlay, so unfortunately you won't be able to affect its behavior.
You can take a screenshot using Fitbit Studio when the indicator is visible to ensure your design is not obscured.
01-09-2018 13:08
