01-01-2021 22:28
01-01-2021 22:28
I'm using SDK 4.2 to make an app for Versa devices. I'm using
<link rel="import" href="/mnt/sysassets/widgets/square_button_widget.gui" />
for my buttons.
Before I click anything this is what it looks like.
When I click one of them and it goes to a different page and I return back to this page it looks like this.
this is the same for all the buttons
CODE FOR CHRISTMAS BUTTON
<use id="christmasButton" href="#square-button" class="firstBtn listBtn">
<set href="#text" attributeName="text-buffer" to="Christmas"/>
<set href="#text" attributeName="font-size" to="24"/>
</use>
JAVASCRIPT CODE FOR CHANGING VISIBILITY
backButton.onactivate = (event) => {
datePage.class = "hidden";
listPage.class = "visible";
christmasButton.onactivate = (event) => {
datePage.class = "visible";
listPage.class = "hidden";
I have also tried the following attributes to fix the issue
<set href="#text" attributeName="x" to="50%"/>
<set href="#text" attributeName="text-anchor" to="middle"/>
01-02-2021 03:21
01-02-2021 03:21
I found a solution which involves not using the provided text.
The example is on the back button
<use id="backButton" href="#square-button" class="back">
<text class="btnText">BACK</text>
</use>
Use <text class="btnText"></text>
.btnText {
font-family: System-Light;
font-size: 24;
text-anchor: middle;
text-length: 32;
fill: white;
x: "50%";
y: "60%"
System-Light appears to be the font used. I can't confirm but it's very close.
50%, 60% gets it as close to centre as possible.
With this solution, the text doesn't move and is as close to a fix as I could get.
01-02-2021 03:21
01-02-2021 03:21
</use>
.btnText {
font-size: 24;
text-length: 32;
fill: white;
x: "50%";
y: "60%"
