10-12-2017 10:35
10-12-2017 10:35
I have a very simple TextInput right now:
<TextInput settingsKey='code' label='Code' />
In my companion code on the settingsStorage.change event, the event key is correct ("code"), however the newValue returns a JSON string "{"name":"1234"}" instead of the expected value "1234". Is this expected behavior?
10-18-2017 16:44
10-18-2017 16:44
It's a known issue and we'll be looking to fix this in the future.
10-18-2017 16:44
10-18-2017 16:44
09-16-2018 17:11
09-16-2018 17:11
Is this fixed?
Best Answer09-16-2018 17:12
09-16-2018 17:12
Is there a workaround?
Best Answer12-30-2018 08:35
12-30-2018 08:35
I am using this workaround
<TextInput
label="IP:PORT"
value={props.settings.address}
onChange={value => props.settingsStorage.setItem('address', value.name)}
Best Answer04-13-2019 13:10
04-13-2019 13:10
Still not working correctly?
08-17-2021 17:40
08-17-2021 17:40
Has it been fixed with SDK 6? SDK 4.3 still has this issue especially using a for loop for multiple contacts
[ '{"name":"+"}', '+1212', '+1212', '+1212' ] Where the first retrieved has this issue and then the rest don't. It creates a consistency issue.
08-17-2021 17:59
08-17-2021 17:59
Using .name on those values returns null, because it should be ."name" which returns a error
