08-07-2019 06:33
08-07-2019 06:33
Whenever I try to build an app I get the message "There are no SDKs available in Studio to build this project.". If I am supposed to download/install an SDK to my computer, could somebody please give me the url from which it can be downloaded?
08-07-2019 07:59
08-07-2019 07:59
It sounds like an old project which needs to be updated to use a more recent version of the SDK.
Click on the package.json file and select the latest SDK version, then you should be able to build.
08-07-2019 07:29
08-07-2019 07:29
Hi @GPMc - I’ve moved your post to the SDK Development forum. You are more likely to get an answer there. Good luck!
08-07-2019 07:34
08-07-2019 07:34
08-07-2019 07:59
08-07-2019 07:59
08-07-2019 15:44
08-07-2019 15:44
