I'm using a Tile List with Checkbox Tile items. I want to treat the list like radio buttons so only one item in the list can be selected at a time. I have a couple of ideas but I need to know how to call the onclick event for an item programatically or how to change an items checkbox image from checked to not checked programmatically. Any ideas?
Best AnswerI'm using the onclick of title it to change the color of the selected item; I'm just really giving the tile an id and using getElementById to get at the tile.
The line of code after the for loop setting the value to 0 fixes a bizarre problem where all the tiles are in the first row layered together.
My code is in github if you want an example https://github.com/grumpy-coders/pointy/blob/master/app/screens/select-player.js
But I'll just paste the piece that you care about:
for (let playerIndex = 0; playerIndex < availablePlayers.length; playerIndex++) {
if (availablePlayers[playerIndex] == null) {
continue;
let cbTile = screen.getElementById('chk' + playerIndex);
if (cbTile != null) {
cbTile.text = availablePlayers[playerIndex].name;
cbTile.playerID = availablePlayers[playerIndex].playerID;
cbTile.style.display = 'inline';
cbTile.getElementById('checkbox').getElementById('header').getElementById('text').style.fill = 'fb-yellow';
cbTile.firstChild.value = 0;
cbTile.firstChild.onclick = function () {
cbTile.getElementById('checkbox').getElementById('header').getElementById('text').style.fill = cbTile.firstChild.value == 0 ? 'fb-green' : 'fb-yellow';
screen.getElementById('tile-list').value = 0;
continue;
