I'm having difficulty rotating an image right now since I can't set the transform origin. I'm not quite sure how you get this to work?
SVG doesn't seem to like this:
transform="rotate(45, 168, 168)"
Error 22 Invalid rotate value '45, 168, 168'
Going by this explanation, it should work
rotate(angle | angle, cx, cy): specifies a rotation by angle degrees about a given poin cx, cy. If the optional coordinate parameters are not supplied, the rotation is about the origin of the element.
It may be the origin is calculated somewhere else or it only works for certain items or has to be defined in a certain way.
Couldn't find the method to make it work consistently for all items in SDK 6 either.
I've tried including a transform translate but that only seems to translate the image and not the origin point once I try to rotate it. It's just weird how the SVG documentation mentions you can change the transform origin but yet it doesn't work in code
