10-17-2017 23:19
10-17-2017 23:19
The transparent png files for the LCD Clock Example appears correctly in the Ionic watch as transparent.
However, any other transparent png file imported into the project has a white background. Are there any documentation on how a transparent png file is supposed to be created?
Best Answer10-18-2017 11:55
10-18-2017 11:55
The LCD clock face uses 8-bit PNG with transparency. Then you can use a fill color to affect the white/grey areas of the image using grayscale magic.
PNG image data, 69 x 109, 8-bit gray+alpha, non-interlaced
I've used just a transparent PNG, without a fill:
runner.png: PNG image data, 348 x 250, 8-bit/color RGBA, non-interlaced
10-18-2017 11:55
