Transparent PNG background appears white
ANSWERED
The transparent png files for the LCD Clock Example appears correctly in the Ionic watch as transparent.
However, any other transparent png file imported into the project has a white background.  Are there any documentation on how a transparent png file is supposed to be created?
1 BEST ANSWER
Accepted Solutions
The LCD clock face uses 8-bit PNG with transparency. Then you can use a fill color to affect the white/grey areas of the image using grayscale magic.
PNG image data, 69 x 109, 8-bit gray+alpha, non-interlaced
I've used just a transparent PNG, without a fill:
runner.png: PNG image data, 348 x 250, 8-bit/color RGBA, non-interlaced
1 REPLY 1
