Hello everyone,
I am trying to run the tumblerview example from:
https://dev.fitbit.com/build/guides/user-interface/svg-components/views/#tumbler-view
when I do, the display shows the first value to be 'New Value', it's just taking the first value variable as the name of the variable itself? all the other values show up ok. I checked the index.gui and everything seems to be fine but obviously, something is wrong. Can someone help, please.First Value Shows as variable?index.js
import document from "document";
let tumbler = document.getElementById("tumbler");
let selectedIndex = tumbler.value;
let selectedItem = tumbler.getElementById("item" + selectedIndex);
let selectedValue = selectedItem.getElementById("content").text;
console.log(`index: ${selectedIndex} :: value: ${selectedValue}`);
selectedItem.getElementById("content").text = "New Value";index.gui:
<svg viewport-fill="fb-cyan">
<use id="tumbler" href="#tumblerview">
<use id="item0" href="#tumbler-item" class="item">
<text id="content">01</text>
</use>
<use id="item1" href="#tumbler-item" class="item">
<text id="content">02</text>
</use>
<use id="item2" href="#tumbler-item" class="item">
<text id="content">03</text>
</use>
<use id="item3" href="#tumbler-item" class="item">
<text id="content">04</text>
</use>
<use id="item4" href="#tumbler-item" class="item">
<text id="content">05</text>
</use>
<use id="item5" href="#tumbler-item" class="item">
<text id="content">06</text>
</use>
<use id="item6" href="#tumbler-item" class="item">
<text id="content">07</text>
</use>
<use id="item7" href="#tumbler-item" class="item">
<text id="content">08</text>
</use>
<use id="item8" href="#tumbler-item" class="item">
<text id="content">09</text>
</use>
<use id="item9" href="#tumbler-item" class="item">
<text id="content">10</text>
</use>
<use id="item10" href="#tumbler-item" class="item">
<text id="content">11</text>
</use>
<use id="item11" href="#tumbler-item" class="item">
<text id="content">12</text>
</use>
<use id="item12" href="#tumbler-item" class="item">
<text id="content">13</text>
</use>
<use id="item13" href="#tumbler-item" class="item">
<text id="content">14</text>
</use>
<use id="item14" href="#tumbler-item" class="item">
<text id="content">15</text>
</use>
<use id="item15" href="#tumbler-item" class="item">
<text id="content">16</text>
</use>
<use id="item16" href="#tumbler-item" class="item">
</use>
<use id="item17" href="#tumbler-item" class="item">
<text id="content">17</text>
</use>
<use id="item18" href="#tumbler-item" class="item">
<text id="content">18</text>
</use>
<use id="item19" href="#tumbler-item" class="item">
<text id="content">19</text>
</use>
<use id="item20" href="#tumbler-item" class="item">
<text id="content">20</text>
</use>
</use>
</svg>styles.css:
#tumbler { y: 50%-50; }
.item { height: 90; }
.item text { font-size: 80; fill: white; x: 5; text-length: 8; }widget.gui
<svg>
<defs>
<link rel="stylesheet" href="styles.css" />
<link rel="import" href="/mnt/sysassets/widgets_common.gui" />
<!-- Additional Imports -->
<link rel="import" href="/mnt/sysassets/widgets/baseview_widget.gui" />
<link rel="import" href="/mnt/sysassets/widgets/tumblerview_widget.gui" />
</defs>
</svg>Thank you in advance.
