09-28-2021 13:52 - edited 09-29-2021 05:02
I'm creating an app that checks if two objects are touching by looking at their x and y coordinates and seeing if they are within a certain range using if else statements. The code I have ensures that they will be inside the specified range unless the screen is clicked in time. However, the code below does not seem to register if the objects are with the specified range when they are not clicked in time.
In the index.js file:
import * as document from "document";
let image1 = document.getElementById("image1");
let image2 = document.getElementById("image2");
if (image1.x < 60 && image1.x > 20 && image2.y > 200) {
console.log("touching");
} else {
console.log("not touching");
In the index.gui file:
<image id="image2" x="20" y="200" width="25%" height="25%" href="image2.png" pointer-events="visible" >
<animate attributeName="y" begin="mousedown" from="65%" to="45%" dur="1"/>
<animate attributeName="y" begin="mousedown+1" from="45%" to="65%" dur="1"/>
</image>
<image id="image1" x="200" y="200" width="25%" height="25%" href="image1.png" pointer-events="visible" >
<animate attributeName="x" begin="load" from="95%" to="5%" dur="2" repeatCount = "indefinite"/>
</image>
08-10-2022 07:22 - edited 08-10-2022 07:42
Thanks to the help of @SunsetRunner, this is my final code:
index.js:
const image1 = document.getElementById("image1");
const image2 = document.getElementById("image2");
var image1Instance = document.getElementById("image1Instance");
var image1Group = image1Instance.getElementById("image1Group");
var image2Instance = document.getElementById("image2Instance");
var image2Group = image2Instance.getElementById("image2Group");
var gameOver = 0
image2Instance.animate("enable");
setInterval(function () {
if (gameOver === 0) {
let image1Coords = image1.getBBox();
let image2Coords = image2.getBBox();
if (image2Coords.x < 60 && image1Coords.y > 200) {
gameOver = 1;
if (gameOver === 1) {
console.log("Game Over!");
}, 250);
image1.addEventListener("click", (evt) => {
image1Group.groupTransform.translate.y = -30;
setTimeout(() => {
image1Group.groupTransform.translate.y = 30;
}, 700);
index.gui:
<defs>
<symbol id="image2HRef">
<g id="image2Group" >
<image id="image2" x="200" y="200" width="25%" height="25%" href="image2.png" pointer-events="visible" />
<animateTransform attributeType="translate" begin="enable" from="250,0" to="0,0" dur="1.5" repeatCount = "indefinite" />
</g>
</symbol>
</defs>
<svg width="100%" height="100%">
<use id="image2Instance" href="#image2HRef" width="100%" height="100%" />
</svg>
<defs>
<symbol id="image1HRef">
<g id="image1Group">
<image id="image1" x="20" y="200" width="25%" height="25%" href="image1.png" pointer-events="visible" />
</g>
</symbol>
</defs>
<use id="image1Instance" href="#image1HRef" width="100%" height="100%" />
</svg>
It appears that I have switched images 1 & 2 around from my original post ... Not sure how that happened!
09-28-2021 22:01
09-28-2021 22:01
Did you really mean?
09-28-2021 22:10
09-28-2021 22:10
That line of code is only going to be executed once (at startup). I don't know if JS x and y are updated during SVG animations.
09-29-2021 05:09
09-29-2021 05:09
@Guy_ Isn't that the code I have?
@Gondwana The code in the index.js file is inside a ontick() handler that ticks every second. Every second, it is consoling "false." I would attach a screenshot if I knew how.
clock.granularity = "seconds";
clock.addEventListener("tick", (evt) => {
} else {
09-29-2021 05:13
09-29-2021 05:13
@Sagrawal8 - the IF seems odd, can image1.x ever be both < 60 AND > 20 ?
09-29-2021 06:25 - edited 09-29-2021 06:26
@Guy_ - image1.x could be both less than 60 and greater than 20 because the image is sliding across the screen, so for a short time, its x value is between 20 and 60.
09-29-2021 06:30
09-29-2021 06:30
@Sagrawal8- perhaps you need OR not AND?
09-29-2021 06:39
09-29-2021 06:39
@Guy_ I tried that and that always consoled true.
09-30-2021 05:30
09-30-2021 05:30
In order to figure out why my code was always consoling false, I consoled the values of the image1.x and image2.y. It appears the index.js file was not updating their values. image1.x always consoled 0, and image2.y always consoled 200 until it was clicked, and then it consoled 0. @JonFitbit Do you anyway to fix this?
08-09-2022 08:02
08-09-2022 08:02
@Gondwana You never seem to have responded to me regarding this thread, which has been dormant for a while. Maybe image1.x and image2.y is not the way to read their x/y coordinates, respectively? Also, could it be that because the animation is taking place in the index.gui it is registering properly? Thanks in advance.
08-09-2022 09:51
08-09-2022 09:51
A wild guess:
It might be possible that you can't log the coordinates as you had set to % in your animation.
Perhaps try with integers instead.
08-09-2022 10:57
08-09-2022 10:57
@SunsetRunner Yeah, I thought that might have been the issue too, but after fiddling around with it, I had no luck.
08-09-2022 11:17
08-09-2022 11:17
So you can't even log the values? Or is it just your if statement not logging?
08-09-2022 11:27 - edited 08-10-2022 07:46
@SunsetRunner Whether I specify pixels or just use percentages makes no difference regarding what is consoled. See this post from about a year ago:
08-09-2022 12:06
08-09-2022 12:06
Hi @Sagrawal8 - Don't know your setup but have you tried setting the x y values in the code - may be after that it will be accessible.
08-09-2022 12:55 - edited 08-09-2022 13:00
I tested a bit out of curiosity. It seems actually that the SVG <animate/> can't be logged in js.
But I found a workaround to use in SVG:
You can wrap your image in a group, then do a animateTransform translate inside that group.
You can then console.log the coordinates like
groupName.groupTransform.translate.x (or y)
<g id="anim1">
<image id="image1" y="0" width="25%" height="25%" href="image1.png" pointer-events="visible"/>
<animateTransform attributeType="translate" from="200,250" to="0,250" easing="linear" begin="load" dur="2" repeatCount="indefinite"/>
</g>
08-09-2022 13:31
08-09-2022 13:31
@Guy_ The coordinates are set in the index.gui file, but it seems that it is not registering in the index.js file. Everything regarding the set-up is in the original post.
08-09-2022 13:33
08-09-2022 13:33
Thanks, @SunsetRunner, but are you actually able to log the coordinates using the method you described?
08-09-2022 13:40
08-09-2022 13:40
08-09-2022 13:43
08-09-2022 13:43
@SunsetRunner So what code did you use to log the coordinates? Also, how would I set the interval to be less than 1000ms? The smallest tick possible is a second based on the Fitbit docs.
