I don't understand what types of images I can use. I have tried a million different jpgs and pngs. Sometimes they display and I can resize and reposition them. Sometimes they are full screen and I can't change it. Sometimes they don't show at all. I haven't found a pattern.
Any help is appreciated
thank you
@Rozeyt wrote:I don't understand what types of images I can use. I have tried a million different jpgs and pngs. Sometimes they display and I can resize and reposition them. Sometimes they are full screen and I can't change it. Sometimes they don't show at all. I haven't found a pattern.
thank you
PNGs seem to work best as they are translated into a hardware accelerated format. Animated pngs don't seem to work.
I use an online media editor to resize pngs to the size the clockface will be using, and to change non-png image files to pngs.
Also, don't keep your work-in-progress (WIP) files in the resource directory, everything there gets download to the watch whether you use it or not.
Best AnswerIt's best if you resize images to no larger than the size of the watch screen (in pixels), unless you're striving for a special effect. Even then, the allowable maximum size is very limited.
Don't try to resize them on the watch. Do it beforehand.
Don't try progressively-encoded JPGs.
PNGs should be 8-bits-per-channel RGB unless you're using greyscale colouring.
