10-10-2023 02:49
10-10-2023 02:49
Hi all, I'm following this guide https://dev.fitbit.com/getting-started/
I have:
However, while in "npx fitbit" I type "install" it says "No devices are connected and available". Typying "connect device" reports the same error. Instead typying "connect phone" correctly connects to my android app.
I'm using node 14 as suggested. The pc, the android phone and the fitbit device are all connected to the same WiFi network.
Best Answer10-10-2023 12:04
10-10-2023 12:04
The SDK for Sense 2 development hasn't been released. You might be able to verify that this is the problem by checking the build targets you set in project.json.
I'm also not sure whether current Sense 2 firmware fully supports the USB dev bridge.
Best Answer10-10-2023 23:12 - edited 10-10-2023 23:13
Hi @simondvt - if you manage to create an app or clock for the Sense 2 and load it to the Gallery you can install it via the Gallery private link [OPEN APP}.
However you cannot test it with this method. Without a Simulator, or direct load to the watch, you won't have a console log. Someone reported installing a USB driver for the PC had worked, however.
There are many differences to the current SDK and without knowing what they are and without a log it will be difficult to resolve any issues you may have.
Of course if it is a very simple thing you are creating it may just work with the private link, but you won't be able to publish it in the Gallery.
10-11-2023 05:18 - edited 10-11-2023 07:00
@simondvt- a thought - if you want to develop and test, switching to a Sense, Versa 3 or 2 may be the way to go which have features the Sense 2 doesn't, at least you can develop using the simulator.
If you just got the watch Fitbit have a 45 day refund policy or possibly authorised dealers too, some stores provide 14 to 30 day refunds.
