Looking for help in implementing the { gettext("string") } in the settings index.jsx file within an array map such as below. Any help is appreciated.
const arrayInfo = [
['Label 1', 'placeholder 1', 'settingskey1'],
['Label 2', 'placeholder 2', 'settingskey2'],
['Label 3', 'placeholder 3', 'settingskey3'],
arrayInfo.map(([label, placeholder, settingsKey]) =>
<TextInput
label={label}
placeholder={placeholder}
settingsKey={settingsKey}
Best AnswerAre you looking for a way to generate a list of UI components in a loop?
I rewrote your code as follows
First, declare an array of info object,
const arrayInfo = [{
label: 'Label 1',
placeholder: 'Place holder 1',
settingsKey: 'settingsKey 1'
label: 'Label 2',
placeholder: 'Place holder 2',
settingsKey: 'settingsKey 2'
label: 'Label 3',
placeholder: 'Place holder 3',
settingsKey: 'settingsKey 3'
<Page>
{arrayInfo.map((value, index) => {
return <TextInput
label={value.label}
placeholder={value.placeholder}
settingsKey={value.settingsKey}
</page>
If everything checks out, you will have the list of UI elements rendered in the settings page
Best AnswerYour breakdown does the same thing that I am doing today. The way that I am doing it is an attempt to minimize code because I would have 5 of these arrays with 10 selections is each.
I believe I would also have the same issue using the i18n code because I would need to wrap the string in the array info object. I am doing that now and its not working.
