12-22-2020 09:35
12-22-2020 09:35
So I am currently trying to use an icon button according to the documentation: https://dev.fitbit.com/build/guides/user-interface/svg-components/buttons/
but it does not seem to be working, and I think the docs are for a more recent version of the SDK (presumably 5.x) I also tried modifying this: https://community.fitbit.com/t5/SDK-Development/Simple-button-example/td-p/2639981 to work but no luck with that either. It seems as if this was one of the things that changed around a good bit in the migration, but even reversing the changes here didn't yield a new result: https://dev.fitbit.com/build/guides/migration/ (4.x to 5.0). A simple example or explanation would be great, many thanks
widgets.gui
<svg>
<defs>
<link rel="stylesheet" href="styles.css" />
<link rel="import" href="/mnt/sysassets/widgets_common.gui" />
<link rel="import" href="/mnt/sysassets/widgets/icon_button.gui"/>
</defs>
</svg>
index.gui
<use id="button-1" href="play.png" class="small-button application-fill plus-button" />
style.css
#button-1 {
x: 30;
y: 30;
Error in CLI
App: Error 2 Invalid path '/mnt/sysassets/widgets/icon_button.gui'
[12:20:48 PM] App: Error 22 Invalid value '' (mnt/sysassets/widgets/icon_button.gui:1,1)
[12:20:48 PM] App: Error 22 Could not find symbol 'play.png' in button-1 (resources/index.gui:11,1)
[12:20:48 PM] App: Error 22 Undefined attribute 'href' in button-1
Best Answer01-04-2021 07:33
01-04-2021 07:33
Unfortunately the SDK5 components won't work on SDK4 devices.
You can find the old documentation on the waybackmachine. You want the icon button. https://web.archive.org/web/20191102093406/https://dev.fitbit.com/build/guides/user-interface/svg-co...
