01-03-2018 11:34
01-03-2018 11:34
I am using the following in my index.jsx file:
<TextInput
label="Your Name"
placeholder="Please enter your first and last name"
settingsKey="userName"
What I would like to do is pass the name the end user types in and saves to the index.gui. I currently have:
<text id="userName" x="10%" y="85%"
font-family="Colfax-Medium" fill="black"
font-size="30" font-weight="bold"
text-anchor="start">This is the users name </text>
The id is not passing it obviously. How would I get this information to pull from the .jsx file?
01-05-2018 11:40
01-05-2018 11:40
Thanks for that. I got it working. The problem after getting it to transfer is that it displays in the JSON format which I see is a whole different issue. I was able to work around that with the following:
messaging.peerSocket.onmessage = evt => {
console.log(`App received: ${JSON.stringify(evt)}`);
if (evt.data.key === "userName" && evt.data.newValue) {
let userName = util.stripQuotes(evt.data.newValue);
let strName = util.stripQuotes(JSON.stringify(userName));
var stripNameFront = strName.substr(6, strName.length-2);
var stripNameBack = stripNameFront.substr(0, stripNameFront.length-1);
let name = ("Name: " + stripNameBack)
var nameUser = document.getElementById("nameUser");
nameUser.text = name;
01-03-2018 11:42
01-03-2018 11:42
Alas, nothing happens automatically. You have to capture the text changes in a companion app, use a message or file transfer to push them to the watch, and then display them using JS in the watch app (eg, setting the 'text' attribute of the relevant element declared in your index.gui).
I'm pretty sure you can't write anything directly to index.gui.
01-03-2018 21:06 - edited 01-03-2018 21:18
You can use the onChange setting for the textInput to save your input to props.settingsStorage. You can then access the settingsStorage in the companion and pass it back via messaging or file transfer to the device gui.
01-05-2018 11:40
01-05-2018 11:40
01-05-2018 17:48
01-05-2018 17:48
If you end up having more than one setting in the settings.jsx, this will work:
settingsStorage.onchange = function(evt) {
//console.log(JSON.stringify(evt));
var obj = JSON.parse(evt.newValue, function (event, value) {
console.log(evt.key + ": " + value);
//doSomething(evt.key, value);
05-23-2018 19:11
05-23-2018 19:11
Hey, just wanted to let you know that there is much easier way to get the value in a TextInput field:
JSON.parse(evt.data.newValue).name
08-17-2021 18:19
08-17-2021 18:19
Doesn't work for textinput user inputted data, reports null because the <name> part is in " so it's "name" and that causes issues
