This code segment works on the simulator but causes trackers to go back to the home screen (ends immediately). If I comment this section out, everything else works. Thoughts?
//Scroll Display
VTList.delegate = {
getTileInfo: function(index) {
return {
type: "my-pool",
value: minSec(actLapTime[index]),
index: index
configureTile: function(tile, info) {
if (info.type == "my-pool") {
tile.getElementById("text").text = `${info.index + 1} ${info.value}`;
console.log(`config loop ${info.index + 1} ${info.value}`);
// VTList.length must be set AFTER VTList.delegate
VTList.length = NUM_ELEMS;
The console.log displays the info correctly. Once again...It works on the simulator but not on anyones actual devices.
Here is the matching part of the index.gui...
<defs>
<symbol id="my-tile-item" href="#tile-list-item" focusable="false"
pointer-events="none" system-events="all" display="none">
<text id="text" />
<rect id="tile-divider-bottom" class="tile-divider-bottom" />
</symbol>
</defs>
<use id="my-list" href="#tile-list" opacity = "0.3">
<var id="virtual" value="1" />
<var id="reorder-enabled" value="0" />
<var id="peek-enabled" value="0" />
<var id="separator-height-bottom" value="2" />
<use id="my-pool" href="#tile-list-pool">
<use id="my-pool[0]" href="#my-tile-item" class="tile-list-item" />
<use id="my-pool[1]" href="#my-tile-item" class="tile-list-item" />
<use id="my-pool[2]" href="#my-tile-item" class="tile-list-item" />
<use id="my-pool[3]" href="#my-tile-item" class="tile-list-item" />
<use id="my-pool[4]" href="#my-tile-item" class="tile-list-item" />
<use id="my-pool[5]" href="#my-tile-item" class="tile-list-item" />
<use id="my-pool[6]" href="#my-tile-item" class="tile-list-item" />
<use id="my-pool[7]" href="#my-tile-item" class="tile-list-item" />
<use id="my-pool[8]" href="#my-tile-item" class="tile-list-item" />
<use id="my-pool[9]" href="#my-tile-item" class="tile-list-item" />
</use>
</use>
I have posted this question before and have gotten zero responses with help.
