Hello,
I am working on my clockface. I have a background picture and am able to change the font displayed on it using the companion app settings. What I can't figure out is how to change the background mage. I have a selector which allows me to choose between image file names (when the developer menu actually shows my side-loaded app). I get how to implement that information within the different CSS items preceding with a #, but how do I apply the information to an image listed in the SVG? I'm obviously a noob and am hopefully missing something obvious and easy.
I want to be able to change "Boat.png"
<svg class="background"> <image href="Boat.png" /> <text id="myLabel" /> <text id="myUTCLabel" pointer-events="visible"/> <text id="myCal" pointer-events="visible"/> <text id="today" pointer-events="visible"/> <text id="mySteps" pointer-events="visible"/> </svg>
What I have so far...
messaging.peerSocket.onmessage = evt => {
console.log(`App received: ${JSON.stringify(evt)}`);
if (evt.data.key === "color" && evt.data.newValue) {
let color = util.stripQuotes(evt.data.newValue);
console.log(`Setting background color: ${color}`);
myLabel.style.fill = color;
myUTCLabel.style.fill = color;
myCal.style.fill = color;
mySteps.style.fill = color;
} else if (evt.data.key === "pic" && evt.data.newValue) {
let pic = util.stripQuotes(evt.data.newValue);
console.log(`image selected: ${pic}`);
Something like this:
Give your image an ID:
<image id="myImage" href="Boat.png" />
Then get a handle on the image:
let myImage = document.getElementById("myImage");
Then inside your onmessage event handler, set the image href:
myImage.href = pic;
myImage.href = pic;
