05-29-2024 18:12
05-29-2024 18:12
I'm working on developing my first watch face for the versa 2. I went through the getting started guide and to the npx create-fitbit-app my-first-clock and followed the prompts in there. I got to the part where you select a device and versa 2 isn't an option. It seems like my issue could be that the current SDK version is 6.0 but I need 4.2 for the versa 2. I attempted editing the package.json file and rerunning it like others said but didn't seem to do anything. Just that the versa 2 option I have selected for the simulator isn't compatible with the current version as I selected versa 3 at the beginning since there was no versa 2 option. Is there a way to have the versa 2 option during the first step?
05-29-2024 19:11
05-29-2024 19:11
05-30-2024 05:26
05-30-2024 05:26
Awesome! Thank you. I'll give it a shot.
06-07-2024 14:25
06-07-2024 14:25
I tried what you mentioned in the guide and the command npx create-fitbit-app myVersa2Project --sdk-version 4.3.0 works perfectly. Thank you so much!!
12-06-2024 06:32
12-06-2024 06:32
Thank it helped me so much
