Hi all,
I just created a custom clock face with the SDK v4.2, which means supporting everything up to Versa2.
Now I want to extend this clock face for Versa3 and Sense using SDK v6.1.
Do I have to treat it like a new project, or there is a way to upgrade my current/existing project?
What is the best way to do it?
Best AnswerDoes this mean that I have to do the following:
Additional questions:
That sounds exactly right. I deduce that you're using Studio. I haven't used that for years, but I think you may be able to adjust the build targets while you're hacking package.json. You probably want atlas and vulcan.
Be careful not to destroy your current Studio project. It might be best to use a separate Studio project for the SDK6 build, with files copied across.
Hi @Gondwana,
Thank you for the suggestions and your support.
The approach worked I just got my changes approved and published, so the app is available for all FitBit devices.
Thanks once again and all the best.
Cheers
