03-06-2022 04:00
03-06-2022 04:00
Hi,
Now that the Voluntary Safety Recall of Fitbit Ionic Smartwatches process is executed what does that mean to existing apps for the Ionic?
Will those apps be removed from the Fitbit gallery and is it possible to publish new apps for the Ionic?
BR
GeekBit
03-06-2022 11:12
03-06-2022 11:12
Hi @GeekBit - Apps and Clocks in the Gallery are often available on all watches.
A few might not have been ported to newer watches but normally if you check the gallery for any specific clock or app it will tell you for which watch it is available.
As the recall is voluntary it is unlikely that any Apps or Clocks will be removed from the Gallery or any new updates or new ones will be refused.
