10-29-2018 16:37
10-29-2018 16:37
Hello,
Apologies if this is in other topic. I was looking around and couldn't find a solution for the issue I have. If there is other thread with information that can help me with the issue I'm about to explain, please let me know.
I want to wake up the companion app every a certain time, for debugging purposes I put 5 minutes.
This is the code:
import { me } from "companion";
const MINUTE = 1000 * 60; me.wakeInterval = 5 * MINUTE; console.log("Wake Interval " + JSON.stringify(me.launchReasons)); me.onwakeinterval = evt => { console.log("Inside onwakeinterval"); if (me.launchReasons.wokenUp) { // The companion started due to a periodic timer console.log("Started due to wake interval!"); ... } };
This a link to a printscreen of the logs: https://www.dropbox.com/s/y0kv9d0ov8dz3qg/IMG_1271.jpg?dl=0
What I noticed from the logs is:
My questions are:
me.onwakeinterval = evt => {...};
Hope you can help me with these problems.
Thanks in advance.
11-02-2018 18:15
11-02-2018 18:15
The wakeInterval is only guidance to the mobile runtime to wake the companion, as per https://dev.fitbit.com/build/guides/companion/#periodic-wake-interval
There are 2 states your companion needs to listen for:
1. onwakeinterval - this event fires when your companion is already running and the interval elapses.
2. the launchReason.wokenUp
me.onwakeinterval = evt => { console.log("Companion was already awake - onwakeinterval"); }
11-02-2018 18:15
11-02-2018 18:15
